FANUC are a lead sponsor at North East Manufacturing
Added to MTDCNC by FANUC UK Ltd on 10 May 2015
FANUC is proud to showcase the world’s largest range of robotics and automation products at North East Manufacturing & Engineering 2015.
On FANUC’s B1 stand, the breadth of machining solutions will be showcased, including live demonstrations of the D21LiA5 ROBODRILL, a new high power series compact machining centre. The D21LiA5 enables greater efficiency, specifically when machining aluminium parts due to its high speed acceleration 24000rpm spindle. Its direct drive 5-axis rotary table guarantees a higher level of precision.
FANUC’s Robocut C400iA machine will demonstrate the high reliability and performance of its wire-cut electric discharge offering. The C400iA includes two new functions: Ai corner shape compensation, shortening cutting time by 31 per cent, and new AWR(Auto Wire recovery) at breakpoint in Taper Cutting AWF(Auto Wire feed) in cut path with up to 5 degrees taper.
Also being showcased on the stand is the LRMate 200iD - one of FANUC lightest loading and unloading robots in its class. The robot uses advanced intelligent functions for loading and unloading and its light weight means that the LRMate 200iD can easily integrate into a machine, or mount upside-down on a frame. Its high rigidity arm and most advanced servo technology enables smooth motion without vibration in high speed operation, and the enhanced wrist load capacity allows the robot to handle multiple pieces of work at the same time.
Finally the M1-iA, a lightweight and compact robot designed for small part handling will demonstrate high speed tool bit arranging. The parallel-link structure provides higher speeds and accuracy compared to traditional assembly robots, with a variety of applications which can be installed in multiple orientations.
In addition, FANUC’s B33 stand will host our team of aftersales and training specialists, providing interactive demonstrations of our training academy, parts availability and maintenance information.
FANUC look forward to welcoming everyone at North East Manufacturing & Engineering
2015 to its stands. For further information please see: http://www.fanuc.eu
