FANUC fit anywhere
FANUC fit anywhere
FANUC fit anywhere
FANUC fit anywhere
Added to MTDCNC by FANUC UK Ltd on 10 May 2015
The fact that machine shops are increasingly busy and becoming more pressed for capacity to fit their often compact workshop is enabling FANUC to demonstrate the benefits of its compact ROBODRILL range of machining centres.
With over 12 machine options in the ROBODRILL line, FANUC has a space-saving solution for all manufacturing facilities. The compact high speed and flexible machine tools are available with an X-axis of 300, 500 or 700mm with a Y-axis of 300+100 or 400mm and a spacious Z-axis of 330mm. This capacity encompasses components in the small to medium size bracket whilst only requiring a floor area of 995 by 2210mm, 1565 by 2040mm or 2115 by 2040mm depending upon the work envelope selected.
Within this compact footprint, FANUC ROBODRILL machines are available in 3 to 5-axis configurations with 10,000 or 24,000rpm high speed and high torque spindles with precision levels in the +/-2micron range. These accomplished workhorses are recognised to reduce cycle times by over 40% with their high speed and high torque BT30 spindle configurations that is coupled with unrivalled flexibility. Despite the small footprint, the ROBODRILL can accommodate workpieces up to 400kg with productivity levels that are truly staggering. This is a great example of how a small and compact machine tool range can deliver rigidity, productivity, speed, power and flexibility - all in a limited floor space requirement. If you are pressed for capacity and limited with your floor space, isn't it time you took a look at the latest line of FANUC ROBODRILL machines?
