FANUC D21M-IA5 5-axis VMC with either a 10k or 24k spindle
Added to MTDCNC by FANUC UK Ltd on 17 July 2014
The new compact D21M-IA5 5-axis machining centre is now available from FANUC. With a 2-axis rotary table on the machine bed and an optional 10,000rpm spindle or a high speed 24,000rpm spindle, the new machine is ideal for small to medium machining applications that demand the utmost in productivity and precision.
Capable of being used as a 3 or 5-axis unit, the compact and robust new machining centre offers a spacious work envelope of 500mm in the X-axis, 400mm in the Y-axis and 330mm in the Z-axis considering its remarkably small footprint. With a host of exciting innovations built into the new FANUC D21M, productivity and flexibility are at the core of this machine. With a FANUC 31i full simultaneous 5-axis control unit, the operator can program on-line or offline at the machine using the control unit’s user friendly 3+2 guide.
To improve swarf evacuation, tool life and reduce tool changeovers the new D21M machine incorporates a through spindle coolant facility. Whilst this rapidly removes chips from the work envelope.
As far as speed is concerned, the new FANUC D21M-IA5 is beyond most machine tools in its class with 54m/min rapid feed rates with 1.5G acceleration. This cuts non-production times to a bare minimum and ensures that the end user is optimising their productivity.
With regard to the tool carousel, the new FANUC machine has 21 tool positions that can accommodate standard BT30 & BBT30 (Big Plus, taper and face contact tooling) taper spindles. This high speed unit also provides a tool to tool changeover time of 1.6 seconds, further reducing non-cutting times.
Not only does the FANUC D21M offer these astounding productivity levels, its rigid base and high quality configuration give the end user a high precision machine tool with a repeatability of +/-2microns. All these features have been incorporated to maximise productivity for the end user. However, for HSM applications, FANUC can offer an oil & mist extraction unit and additionally, as an automation specialist the Japanese manufacturer can also incorporate robotic pick and place units to load and unload components.
