Haas CNC Machines now have Increased Spindle Power by 50 Percent
Added to MTDCNC by HAAS Automation on 18 September 2012
For 2012, Haas Automation has increased the speed and performance of the standard spindle on its expansive line of 40-taper VMCs, and introduced several new optional spindles.
All Haas VF-1 through VF-12 40-taper VMCs are now equipped with a powerful 8,100-rpm inline direct-drive spindle that is driven by a 30-horsepower vector drive system. The Haas inline system couples the spindle directly to the motor to reduce heat, increase power transmission, and provide excellent surface finishes. An optional 10,000-rpm inline direct-drive spindle is available for shops wanting higher spindle speeds. Both spindles yield 90 ft-lb of cutting torque.
For shops needing additional low-speed torque and wanting the flexibility of a gearbox, two optional gear-drive spindles are also available for standard Haas 40-taper VMCs. The optional spindles provide either 8,100-rpm or 10,000-rpm, and feature a Haas-built, high-precision two-speed gearbox. Both geared spindles yield 250 ft-lb of torque.
The World's biggest CNC machine tool manufacturer, Haas Automation, designs and builds a full range of metal-cutting machine tools including CNC machining centres, lathes and rotary tables.
Haas machine tools and rotary products are built to deliver higher accuracy, repeatability and durability than any other machine tools on the market.
Haas expects to install more than 14,000 machines this year.
Haas Automation UK is the oldest, most established supplier of Haas CNC machine tools outside the USA. Haas UK was formed in 1991 and currently employs over 60 staff, 32 of whom are factory trained service engineers. The company is known for redefining the industry with its award winning levels of service and support.
The company has two main offices in Norwich and Leicester and 8 additional showrooms across the UK and Ireland. Since late 1991, when the company imported the very first HAAS VF-1 into the UK, HAAS Automation has installed more than 6,000 Haas machine units and has won official recognition from California based HAAS Automation Inc. as the most successful international Haas distributor ever.
There are currently more than 130,000 Haas machines installed worldwide.
LATEST PRODUCTS FROM HAAS Automation
What are you looking for?
What is 5 + 3? (Spamcheck)
