Haas stand at MACH 2016
Added to MTDCNC by HAAS Automation on 04 March 2016
Visitors to the 200m2 Haas stand at MACH 2016 will witness cutting demonstrations on ten of the company’s latest model CNC machine tools, including: high-speed vertical machining centres; 5-axis, high-speed machines; mid-sized verticals designed to take big cuts; high-productivity turning centres with live tooling and Y-axis; powerful, small-footprint mini-mill and toolroom machines; and, making its UK debut, the Haas UMC-750SS universal machining centre, which is a 15,000rpm version of the best selling UMC-750.
The UMC-750SS is a 5-axis 40-taper vertical machining centre with 762 x 508 x 508 mm travels and an integrated high-speed trunnion table. The machine is equipped with a powerful 15,000-rpm inline direct- drive spindle driven by a 30-horsepower vector drive system, and comes standard with a high-speed 40+1 tool side-mount tool changer.
The UMC-750SS’s 630 x 500 mm trunnion table features standard T-slots, as well as a precision pilot bore, for fixturing versatility. The trunnion provides +110 and -35 degrees of tilt and 360 degrees of rotation for excellent tool clearance and large part capacity.
The UMC-750SS’s high-speed trunnion table offers 150 deg/sec rapids to quickly position parts to nearly any angle for 5-sided (3+2) machining, or provide full simultaneous 5-axis motion for contouring and complex machining.
The UMC-750SS is equipped with a 15,000-rpm inline direct-drive spindle, and comes standard with Haas Automation’s powerful high-speed machining control software.
