Haas Toolroom Lathes are affordable and easy to use
Added to MTDCNC by HAAS Automation on 03 September 2015
Haas Toolroom Lathes are affordable, easy to use, and offer the precision control of the Haas CNC system. They are very easy to learn and operate – even without knowing G-code. And with the Haas Intuitive Programming System, manual machinists will transition quickly and easily into full CNC – and be cutting parts in minutes.
The TL-1 recently underwent a complete redesign, making it better than ever, with a new enclosure and higher overall performance. The TL-1 has a maximum capacity of 406 x 762 mm. It features a 508 mm swing over the front apron, and now has an A2-6 spindle nose that accepts either an 8" or 10" optional 3-jaw manual chuck, and has a 3.0" bore.
The updated TL spindle is powered by a 12 hp vector drive system and spins to 2000 rpm, with an option for 3000-rpm. Rapids have increased to 11.4 m/min on both X and Z axes, and an optional manual tailstock is available for additional part support. To better contain swarf and coolant and protect the operator, a full metal enclosure is now standard.
The TL-1 comes equipped with Haas Automation’s powerful Intuitive Programming System – a proprietary conversational operating system that makes cutting parts and creating part programs nearly effortless. Through an interactive graphical interface, the control guides the operator through the steps necessary to machine a part.
Operations that would be difficult or even impossible on a manual machine – compound angles, radii, tapers, profiles, ID and OD threading and rigid tapping – are all possible on the TL-1 – without knowledge of G-code programming.
