The new Haas VF-5SS Super Speed Vertical Machining Centre
Added to MTDCNC by HAAS Automation on 26 June 2012
Haas Automation's VF-5SS is based on the shop-proven Haas VF-5 platform 1,270 x 660 x 635mm xyz travels, the Super VF-5 comes standard with an innovative 12,000-rpm inline direct-drive spindle, an ultra-fast tool changer and 35m/min rapids.
The machines are equipped with a 12,000-rpm, 40-taper spindle that features a unique inline, direct-drive system that couples the drive directly to the spindle rather than using belts. This results in smoother transmission of power, less heat and less noise than other drive systems, providing better surface finishes, extreme thermal stability and very quiet operation.
The newly designed 24+1 side-mount tool changer uses lighter materials and a high-performance servo motor, for tool changes that take less than 1.6 seconds tool to tool. High-pitch ballscrews and high-torque servo motors on all axes provide rapids of 35m/min.
The VF-5SS is part of the Haas Super Speed VMC family, which includes VF-2SS, VF-3SS, VF-4SS and VF-6SS. The two smaller machines are also available with an extended Y-axis.
LATEST PRODUCTS FROM HAAS Automation
What are you looking for?
What is 2 + 1? (Spamcheck)
