Heavy duty milling machines for performing roughing-out cycles
Added to MTDCNC by Ajax on 01 March 2015
To meet customer requests for heavy duty milling machines for performing roughing-out cycles such when creating datums for dies and moulds or hogging out, removing scale and harder surfaces prior to resetting for precision machining, Ajax Machine Tools International is introducing its AJVBM Series of vertical milling machines. The non-CNC machine range has travels up to 2,000 mm by 800 mm by 700 mm and up to 11 kW spindle and 3.5 kW feed motor power, with mechanical gearboxes.
The AJVBM Series of four machines can be specified with Heidenhain or Newall 2- or 3-axis digital read-out. Each machine is constructed on heavy duty ribbed castings with the added rigidity created from hardened and ground solid boxways and ISO 50 spindle taper.
The range starts with the AJVBM 3 having a 1,700 mm by 380 mm table and travels of 1,000 mm by 380 mm by 500 mm with up to 600 mm gap between the spindle and table.  The spindle drive is 5.5 kW giving a speed range 45 to 1,500 revs/min in 12 steps and the feed range is variable between 20 and 1,000 revs/min.
The largest machine, the AJVBM 8 weighs in at 11.8 tonnes with a 2,700 mm by 750 mm table with up to 770 mm between spindle and table. Travels are 2,000 mm by 800 mm by 700 mm.  The 11 kW spindle has infinitely variable speed range between 45 and 1,500 revs/min and feed rates are variable from the 3.5 kW motor up to 1,000 mm/min.
LATEST PRODUCTS FROM Ajax
What are you looking for?
What is 5 + 6? (Spamcheck)
