Dugard introduces heavy duty Samsung turning Line
Added to MTDCNC by Dugard on 03 July 2015
Dugard has now introduced the new Samsung PL 45LY large bed turning centre for manufacturers that demand a robust and productive machine tool for the machining of large parts.
The impressive build quality of the new Samsung PL 45LY consists of a box guide way with a single piece meehanite casting. This makes Dugard's latest offering a robust unit for machining large shafts with a Y-axis that permits off centre milling and drilling. The configuration of the Y-axis is not a compound slide like many machines, but it is built on two axes. This gives the machine a smaller footprint compared to standard compound Y-axis machines that take considerably more space in the work envelope. Additionally, this feature makes the Samsung faster than alternate machines when moving from one point to another.
From a power perspective, the machine has a huge 37kW spindle motor for heavy machining with outstanding torque levels that is provided by the two stage gearbox. The machine has a turning length of 2m that is easily accessible with two sliding doors at the front of the machine. The large work area, Y-axis milling and exceptional spindle power make the new offering from Dugard ideal for the oil & gas and aerospace sectors or for end users cutting particularly demanding materials.
As standard, the machine is supplied with a programmable tailstock, Fanuc 0i control unit and a 15 inch chuck. With regards to machining capacity, the Samsung PL 45LY has a particularly large 117.5mm bore capacity with a swing over bed of 975mm that supports cutting diameters up to 620mm.
What are you looking for?
What is 6 + 8? (Spamcheck)
