ASQUITH BUTLER Sahos Sprint 3 axis high speed milling machine
Added to MTDCNC by Asquith Butler Ltd on 21 March 2014
Asquith Butler introduces the SAHOS Sprint 3 Axis High Speed Milling Machine. The machine is designed to fit between lightweight CNC Routing Machines and Full 5 Axis machining Centres and is intended for the accurate production of patterns and moulds in various materials from wood, plastics, resins and aluminium due to its over dimensioned structure.
The machine features a full 3D Heidenhain iTNC620 control with HR410 manual handwheel.
Maximum Axis traverse speeds are 20000mm/min. Axes are driven by high specification digital motors and high precision ballscrews.
The excellent spindle characteristics of 0  - 24000RPM with 7.5KW power  provide good versatility in machining a range of materials including Aluminium.
 The machine is fitted with a ISO30 Spindle taper and a 6 pocket Automatic Toolchanger
Various enhancements are available such as:
•    Heidenhain TT140 Tool measuring Probe
•    Vacuum Clamping Table
•    Dust Extraction and Filtration Systems
The machine supplied by leading machine tool builder and supplier, Asquith Butler is aimed at the pattern and tool and mould making industry.
Asquith Butler offer a full range of additional services such as installation, spare and service, programmer and operator training and full applications support from the conveniently located modern premises in West Yorkshire.
The Sahos range extends from the Sprint 3 Axis machine to large overhead travelling beam High Speed machines and are manufactured to a high standard in the Czech Republic.
