Improve productivity with the HAAS VF3SS machining centre
Added to MTDCNC by HAAS Automation on 06 October 2014
The new VF3SS machining centre from Haas Automation has now been launched to improve productivity and capability for the end user.  Based around the established and renowned VF3 platform, the new VF-3SS incorporates a host of new technology that includes a unique inline, direct-drive system that couples the drive directly to the spindle rather than using belts.
The result is less vibration, less heat and less noise than other drive systems. It also delivers better surface finishes, improved thermal stability and very quiet operation. The newly designed 24+1 side-mount tool changer uses lighter materials and a high-performance servo motor. The result is tool changes that take less than 1.6 seconds tool to tool, a clear productivity benefit for the end user. In addition, the new VF3SS has high-pitch ball-screws and high-torque servo motors on all axes that provide rapids of 35m/min with sufficient power for heavy metal removal rates at maximum cutting speeds of 21.2m/min.
All these upgrades are delivered in a package that has a spacious working envelope of 1016 by 508 by 635mm in the X, Y and Z axes respectively. Within this envelope, the operator can benefit from a powerful 22.4kW motor with a 12000rpm spindle speed that drives a BT40 taper tool configuration. This combination delivers power, speed, high levels of torque and a tool taper for large cutting tools that will maximise material removal.
