Ward CNC's new Hyundia Wia L2600SY turning centre
Added to MTDCNC by TW Ward CNC Machinery Ltd on 21 August 2014
With Y axis and able to produce complex parts in a single set-up, the L2600SY multi-tasking turning centre is the latest addition to the comprehensive portfolio of Hyundai-Wia lathes available from exclusive UK distributor, T W Ward CNC Machinery (Ward CNC).
Of 30deg slant bed construction – and with box guideways providing high levels of rigidity and accuracy, even under the heaviest cutting conditions - the L2600SY is a 81 mm bar capacity machine with a 22/18.5 kW spindle motor that produces spindle speeds of 4,000 revs/min (main – 10 inch chuck) and 6,000 revs/min (sub – six inch chuck).
The machine has a maximum turning diameter and length of 420 mm and 750 mm, respectively, and features a Fanuc iSeries CNC.
The L2600SY follows hot on the heels of two other recent additions to Ward CNC’s comprehensive range of Hyundai-Wia CNC lathes, which includes vertical CNC lathes:
- The L800LMA - capable of handling 240 mm diameter bar, the 45/37 kW, 700 revs/min spindle with 18-ton clamping power is ideal for highly accurate machining in intermittent and heavy-duty cutting applications for medium/large workpieces. The machine has a maximum turning diameter and length of 920 mm and 3,250 mm, respectively, and a swing over the bed of 1,050 mm.
- The L160MA turning centre can accommodate bar of 45 mm diameter, has a 11/7.5 kW, 6,000 revs/min main spindle, plus a maximum turning diameter and length of 310 mm and 550 mm, respectively. Swing over the bed is 600 mm.
