New Jabro-Solid cutters designed for roughing and thin-wall applications
Added to MTDCNC by Seco Tools (UK) Ltd on 06 November 2015
Seco Tools has recently expanded its already comprehensive line of Jabro-Solid² end mills to include new cutting tools that enable customers to employ significantly higher feed rates and achieve higher metal removal rates during roughing operations.
The Jabro-Solid² range has also been further extended to include new long-length tools for machining thin wall parts made from aluminium.
JS554-2C Jabro-Solid² tools for improved roughing
JS554-2C universal solid-carbide end mills enable customers to achieve the highest possible feed and metal removal rates during advanced roughing applications.
Featuring the advanced SIRA coating and a stable tapered-core design, JS554-2C tools can perform high-radial width of cut operations which help reduce the number of roughing passes required and help shorten part cycle times. Furthermore, JS554-2C end mills can undertake rough side-milling operations using its entire 2.5*dc cutting length.
Used in conjunction with the applied chip splitters the JS554-2C tools produce short chips which can be easily and reliably removed from the cutting zone and, as such, are ideal for manufacturers involved in unmanned operations.
When compared to other tools in the range, JS554-2C end mills feature enhanced positive frontal teeth geometries with increased chip room for more effective and improved axial helical interpolation operations.
JS554-2C tools are available with cutting lengths of 2.5 x D and provide manufacturers with the option to select straight shank diameters from 4 mm to 20 mm, or Weldon shank diameters from 6 mm to 20 mm.
JS452-L Jabro-Solid² tools for thin-wall applications
JS452-L long-length solid-carbide end mills deliver increased stability and process reliability when machining thin-wall aluminium parts. The tools also make it possible for users to machine these parts at extremely high speeds.
Featuring a polished HEMI Titanium DiBoride (TiB2) aluminium-inert coating, with a low friction coefficient, JS452-L tools exhibit minimal material adhesion/build-up - thus improving tool life. The coating also ensures effective chip removal and heat evacuation from the cutting zone.
JS452-L end mills comprise 54 long-length options with diameters ranging from 8 mm to 20 mm, corner radii ranging from 0.2 mm to 6 mm and are available in both Weldon and cylindrical shank mounting styles.
Furthermore, an extra gash on the tools’ cutter geometry helps maintain the best possible radius form as well as contributing to optimised chip flow – a real advantage when machining aircraft structural components.
