Kerf Builds a Route To Success at MACH 2016
Added to MTDCNC by Kerf Developments Ltd on 04 February 2016
For subcontract profilers, structural steel, construction, rail and heavy engineering professionals attending MACH 2016, Kerf Developments will be expecting its market leading RUR2500 high definition plasma cutting machine to create a spark of attraction for show visitors. Rapidly becoming the choice machine for the 'heavy industry' sectors, the Kerf RUR2500 will be demonstrating its capabilities using Burny Kaliburn’s proprietary UltraSharp technology on Stand 4466.
On the stand, Kerf Developments will exhibit the RUR2500 model alongside the company's latest innovation, the Plasmaster 3015. As an entry-level low cost cutting solution, the Plasmaster will be the perfect complement to market leading RUR2500  that utilises the Kaliburn Spirit high definition plasma cutting technology system. The Rochdale manufacturer will be demonstrating the potential of the RUR range with samples of finished parts that will emphasise the cut quality of holes and external edges that can be cut. Capable of cutting faster than a laser on thicker materials, the RUR2500 will highlight its capabilities and production prospects at the show.
Designed and manufactured for customers with a high production demand, the RUR incorporates a rigid frame design that is ultrasonically stress relieved and manufactured to highly accurate tolerances to provide remarkable performance. It is this robust build quality and precision cutting that has made the RUR2500 such a popular choice for the structural steel and heavy industry sectors.
The RUR2500 has a cut width of 2m and the modular design permits table dimensions to be tailored to the demands of the end user. In addition, Kerf engineers at MACH will be keen to demonstrate the flexibility and potential of the wide range of Kaliburn plasma units and the Kemper fume extraction tables. Additional options for advanced CAD/CAM and nesting solutions as well as a number of fume extraction solutions will also be showcased.
As the UK and Ireland's primary manufacturer of high density plasma cutting and Oxy-fuel cutting equipment and also the UK and Ireland's flagship dealership for the Burny & Kaliburn range of control systems, Kerf will have technical staff on hand at MACH to answer queries and provide solutions to all your cutting and profiling demands.
