New Kitamura 5 Axis vertical machining center at IMTS 2014
Added to MTDCNC by Leader CNC Technologies Ltd on 27 July 2014
Kitamura Machinery, the premier manufacturer of precision horizontal, vertical and 5 axis machining centers, announced that the company will debut its My trunnion 4G full 5 axis Simultaneous Vertical Machining center at IMTS 2014 in Chicago, September 8 - 13, booth S 9148.
The new machining center, which builds upon Kitamura’s current 5 axis offering, will give attendees a compact, high precision machining option for more complex, intricate applications.
The Mytrunnion 4G has been designed specifically for manufacturers and job shops that require higher levels of flexibility and versatility in the materials that they machine. Guaranteed Kitamura quality and value combine to ensure high levels of quality and rigidity for unbeatable tool life and ultra high level accuracies of ±0.00079” and repeatability ±0.000039”.
Mytrunnion 4G Features
Designed for high precision machining of medium to small parts, the Mytrunnion 4G offers a maximum work size of Ø19.7 x 15.7 inches high and a table load capacity of 440Lbs to easily and more productively process parts in a single set up. A simultaneous 5 axis powerhouse, the Mytrunnion 4G incorporates an A Axis tilting trunnion table (120 to +30°) and a rotary C Axis (360°) with a 0.001° minimum indexing command. The trunnion design allows for maximum stiffness and flexibility with the ability to position the work piece closer to the spindle.
Standard is a 40 taper, powerful, 15,000rpm spindle producing the best output range under a variety of cutting conditions, allowing for a maximum range of applications on a variety of materials (titanium, aluminum, steel)
The 20 HP/AC spindle motor with a direct drive, dual contact spindle systems offers the benefits of greater machining rigidity, reduced vibration and super fine finish capabilities.
