Leader CNC and GER announce Grinding Machine Agreement
Added to MTDCNC by Leader CNC Technologies Ltd on 30 April 2013
Leader CNC is proud to announce that it has an agreement to sell and support the diverse range of high quality Spanish built GER CNC grinding centres within the UK.
The addition of these machines will complement the existing Toshiba, Kitamura, KDM, FAT Haco, Unamuno and DMC range of machining centres, turning and boring machines already distributed by Leader CNC.
GER, as one of the leading European brands, has been providing solutions to grinding problems since 1952 and manufactures a wide range of universal, flat surface, cylindrical and vertical grinders. Simple or complex forms can be ground in either a horizontal or vertical plane, with diameters ranging up to Ø2500mm and flat parts up to 6M in length.
As is expected from well established manufacturers, GER machines achieve remarkable levels of accuracy and surface finish and will undoubtedly delight manufacturers in the aerospace and bearing sectors, as well as manufacturers in the oil & gas and power generation industries.
Since the two companies entered into their agreement, Leader CNC has witnessed special interest in the GER UVG Series of large vertical grinding centres which, with their 4 indexable stations, are ideal for medium / large casings and housings.  As part of their promotion throughout Europe, GER recently demonstrated their capability at the Lyon Exhibition and serious interest was shown by several UK manufacturers.
The availability of such machines to the UK marketplace from a company renowned for its service, support and engineering facilities will be of great re-assurance to UK manufacturers.
