McDowell Machine Tool Solutions create partnership with Niles Simmons
Added to MTDCNC by MTDCNC on 24 June 2013
The partnership will allow McDowell to offer UK manufacturing  the full Niles-Simmons product range including Turning and Milling Centres such as the N40 MC (pictured).
The Niles-Simmons Turning and Milling Centres enable efficient, flexible, high-precision, and operator-friendly complete machining of large size and rotationally symmetrical work pieces in one setup.
The MC Series ranges between sizes N20 MC through N60 MC and can be configured as a single slide or multi slide machine. Thanks to the modular building block system, a variety of machining units can be added to offer utmost flexability. By utilising the MC series of lathes, efficiency of process can be enhanced and throughput times reduced.
The MC Series has a range of 5 sizes. The maximum turning length is 7,500mm and maximum swing diameter is 1,500mm. The MC series can undertake complete machining of cpmplex workpieces including processes such as; Turn-Milling, Gun Drilling, Gear Hobbing, Shaping, Long Boring and In Process Gauging.
Further information and full specifications for th MC Series can be found at www.mcdowellmts.com.
McDowell Machine Tool Solutions also represent manufacturers including Unisign, Takisawa and Bost. The company can provide machine tool solutions for industries such as Aerospace, General Machining, Oil and Gas, Energy, Truck and Train and Heavy Industry.
