Multi function machining centre for milling and turning from Brother
Added to MTDCNC by Whitehouse Machine Tools on 04 August 2014
A new concept in high speed machine tool technology is now available from Whitehouse Machine Tools. The new Brother Speedio M140 X1 is capable of both milling and turning, making it a truly multi-functional machine tool.
The new Speedio M140 X1 has a turning spindle that can turn at up to 2000rpm whilst the BT30 machine spindle has the ability to machine at 10,000rpm, making this a completely unique concept to the machine tool market.
The new high quality Brother M140 X1 incorporates a servo driven turret and motors that generate significantly faster acceleration and deceleration of the spindle at 0.2seconds. This improves productivity, efficiency and reduces non-cutting cycle times for the impressive new offering.
The exciting and extremely precise machine tool has 22 tool stations on the ATC that can deliver a staggering chip to chip time of 1.4 seconds. This ATC system can accommodate turning, milling and drilling tools to deliver a completely multi-functional machine tool. Driven by a 18.9kw motor, the power of the M140 X1 is beyond the realms of most BT30 spindle machines.
With a work envelope of 200mm in X-axis, 440mm in the Z-axis and 305mm in the Y-axis, the Brother machine is the machine of choice for components in the small to medium size ranges. The concept behind this machine is that it can complete all processes in one-hit to improve productivity, reduce changeovers and reduce operator intervention. Furthermore, by completing all operations on one multi-function centre, the Brother machine improves quality and consistency for the end user by reducing changeovers from machine to machine.
