View by company
View by company
View by company
New large-capacity box guide-way Doosan Mynx 9500/50 vertical machining centre
There’s more good news from Mills CNC, the exclusive distributor of Doosan machine tools in the UK and Ireland, for manufacturers machining large, high-precision and often complex parts out of difficult-to-machine materials as the company has announced that it has recently added the latest (and certainly the biggest) Doosan Mynx 9500/50 vertical machining centre to its already popular and proven large-capacity Mynx range of machines.
The highly-rigid designed and built box guide-way Mynx 9500/50 is equipped with a powerful (22kW/6000rpm), high-torque (452 N-m) BT 50 dual face and taper spindle for heavy-duty cutting operations. Customers can select either a two-speed gear-box driven or built-in (10,000rpm) spindle configuration.
The machine is versatile and can handle large workpieces (X-axis 2500mm ; Y-axis 950mm and Z-axis 850mm) up to 3500kg in weight (maximum table load) and features a fast servo-driven tool changer (30-position) with 2.5 second T-T-T changeover time for improved productivity.
The Mynx 9500/50’s performance is further enhanced by its integrated spindle cooling system that minimises thermal growth and, as a consequence, improves part accuracies and tool life, and by the machine’s high-efficiency 4-row screw chip disposal system that delivers improved efficiency and process reliability.
The Mynx 9500/50 is also supplied with the easy-to-use and powerful Doosan Fanuc i control.
Like all Doosan machines the Mynx 9500/50 is backed by Mills CNC’s best-in-class after-sales service support as well as Programmer and/or Operator training provided by the CNC Training Academy.
Says Tony Dale, Mills CNC’s Technical Director:
“Mynx 3-axis verticals are used by precision component manufacturers throughout the UK and Ireland (as well as the rest-of-the world), and their reputation for reliability and accuracy is second to none.
“The new Mynx 9500/50 will appeal to precision manufacturers that machine large, heavy work-pieces and who are looking for a competitively-priced vertical machining centre that delivers day-in…day-out, and that represents great value.”
Published on MTD CNC by Mills CNC Ltd on 22 June 2016
Have you seen these videos all relating to Mills CNC Ltd?
Available to purchase from Mills CNC Ltd
Enquire with MTD CNC TODAY
Spam check: What is 1 + 7?
