View by company
View by company
View by company
New Quaser MV 234 from ETG...BIG VMC
A new introduction to the growing family of Quaser vertical machining centres available from the Engineering Technology Group is the MV 234, to date the largest capacity Quaser VMC available in the UK.
With an X axis travel of 2040mm the machine has an overall table dimension of 2210 x 762 making it ideal for machine shops specialising in large mould and die manufacture or in environments where a pallet machining centre is required.
The table has a load capacity of 2000kg with a generous Y-axis travel of 762mmm and Z-axis of 661mm.
The MV 234 features the unique Quaser spindle greasing system that in one installation can support 30,000 hours of machining and can also be replenished via an integral reservoir.
It can be supplied with a 40 or 50 taper spindle options with controls by Fanuc, Siemens or Heidenhain. Tool magazine capacities are 48/60 (40 taper) or 30/40 (50 taper) with through coolant standard at 20 bar - upgradeable to 50 bar.
A range of options are available for the machine – for example an ATC door, linear encoder, spindle oil chiller and work probes.
The machine is available from stock.
For further information contact the Engineering Technology Group at sales@engtechgroup or call 01926 818418.
Published on MTD CNC by ETG on 05 June 2014
Have you seen these videos all relating to ETG?
Available to purchase from ETG
Enquire with MTD CNC TODAY
Spam check: What is 6 + 8?
