Phase 3 CNC Introduce M Series machining centre
Added to MTDCNC by Phase 3 CNC on 20 October 2015
The M series range of Serrtec vertical travelling column machines are now available from Phase 3 CNC. This new product line from Lydney based Phase 3 CNC takes advantage of the best technology available to provide exceptional productivity and quality.
Available with Fanuc, Heidenhain, Siemens or a Fagor control unit, the new Serrtec M6 is a linear drive machine with 3m of longitudinal travel. The M6 is equipped with a 3200x800mm fixed bed that downloads the weight toward the ground and does not place limits in the weight of the workpiece; for this reason the M6 is ideal for machining heavy workpieces, lightweight aluminium parts or heavy steel moulds.
The new M6 machine has X, Y and Z axis travel of 3000 by 800 by 800mm respectively that is covered at breakneck rapid speeds of 60m/min. As standard, the HSK63-A spindle configuration has 12,000rpm with the option of 18,000 or 24,000rpm for high speed machining, which is driven by a powerful 35kW motor.
The machine is supplied with a 30 tool automatic change system that delivers excellent flexibility for the end user. Manufactured with the highest quality components to ensure a machine suitable for continuous production. The perfect base for advanced manufacturing systems, the M6 can be built with your choice of controls, allowing the machine to sit comfortably alongside your existing plant, minimising the amount of training required.
