Phase 3 Introduces High End 5-axis Series of Machines
Added to MTDCNC by Phase 3 CNC on 20 October 2015
Now available from Phase 3 CNC is the MX Series of machining centres from Serrtech. The MX line is regarded as Serrtec's flagship range of incredibly versatile 5 axis CNC machines.
The MX Series features a tilting rotary table and 5 interpolated axes that can be controlled simultaneously, allowing for impressive speed, control and precision. Sitting in the middle of the four model line-up of the MX Series is the MX3. The new MX3 has an X, Y and Z axes travel of 1000 by 600 by 640mm respectively that is capable of machining parts up to 560mm diameter.
The MX3 is supplied with a 12,000trpm spindle that can be upgraded to 18,000 or 24,000rpm for high speed machining applications. The powerful machine has a 35kW spindle drive that rotates the optional ISO 40 or ISO 50 tool-holding configuration. This robust spindle unit can speed around the work area with rapid-feed speeds of 60m/min.
The spindle is supplied cutting tools from an ATC that houses 30 tools as standard with the option of 90 or 120 tool positions. The MX Series is designed with aerospace, energy and mould makers in mind, but its applications are almost endless.
 Built from the highest quality components, the MX3 allows an incredible degree of customisation, with Serrtech able to provide machines to suit your exact requirements. A  choice of spindles are available in high speed and high torque variants that enables Phase 3 CNC to provide the machine tailored to your needs.  Furthermore, the MX range can be supplied with robotic automation or automation ready. Like all machines in the Serrtec line-up, the MX3 is available with Fanuc, Heidenhain, Siemens  or Fagor control units.
