BrightLine fiber, the revolution in laser cutting from TRUMPF
Added to MTDCNC by TRUMPF on 07 December 2013
Solid-state lasers are now more versatile than ever. From mild steel to stainless steel right on to highly reflective materials such as copper and aluminum; from 1 mm to 25 mm sheet thickness – all components of this ball were produced on a solid-state laser machine. Never before could this spectrum of sheet thicknesses and material types be processed on one single machine with excellent quality. Here, the innovation BrigthLine fiber has made the breakthrough possible.
Quality breakthrough in solid-state laser cutting
Thanks to the help of BrightLine fiber, for the first time ever it is possible to achieve excellent quality when cutting thick stainless steel sheets. With the help of this option you can change from thin to thick sheet processing on just one machine depending on the job.
