Starrag Expands Its Five-Axis Range
Added to MTDCNC by Starrag UK Limited on 31 August 2016
These developments not only present a range of smaller yet competitively-priced and high-speed (rapid traverse rates of 65 metres/min) five-axis machines to sub-contract machinists, but they also further enhance Starrag’s impressive array of aluminium cutting machines for OEMs and tier one and two suppliers.
Available from Starrag UK, the portfolio now also includes 150 kW variants for the Scharmann Ecospeed and Ecospeed F models (complementing 120 kW units), that are capable of handling components from three to 20 metres long, while the new Starrag STC 800X features a 120 kW spindle and the three-machine Heckert HEC X5 range has been uprated with 83 kW spindles.
Indeed, the new 150 kW spindles have the potential to reduce machining times by a further 15-20 per cent on typical aerospace structural parts.
In all cases, the machines boast metal removal rates that out-perform ‘like-for-like’ competitor models, Starrag UK claims. Indeed, the STC 800X can remove aluminium at the rate of up to 10 litres a minute.
Metal removal rate is not the only aspect that sets the STC 800X apart. With an A axis range of -110 deg/+60 deg, the machine can complete a range of complex machining features in a single set-up – without the use of an angle head.
In addition, up to 465 tools can be held in the automatic toolchanger and tombstone fixturing permits multi-parts machining. The machine can easily be integrated into a FMS.
Accommodating pallets of 800 mm by 1,000 mm and workloads of 2,000 kgs, the STC 800X has a maximum workpiece swing diameter of 1,400 mm and feed rates of 60 metres/min in the X, Y and Z axes.
Featuring NC-controlled rotary table, the trio of HEC 500 X5, HEC 630 X5 and HEC 800 X5 five-axis machining centres have X, Y and Z axis travels that extend from 1,000 mm by 800 mm by 1,000 mm to 1,450 mm by 1,100 mm by 1,000 mm and are capable of accommodating loads of 1,200 kgs.
In all cases the 83 kW main spindle motor produces speed ranges up to 15,000 revs/min and torque up to 1,500 Nm, plus rapid traverse rates of 65 metres/min.
This reinforces Starrag’s customer-focused policy of ‘Engineering precisely what you value’ by, for example, reducing production times and unit costs by offering complete machining in a single set-up – through the ability to also utilise a wide range of adjustable angle and milling heads, as well as boring bars – and high process reliability due to machine build principles based on, for instance, temperature control/compensation and thermo-symmetrical design.
In tandem with the new 150 kW spindles for the Ecospeeds, Starrag has also announced the development of chatter monitoring function for automatic recognition and analysis of unstable machining processes.
In short, the functionality continuously monitors spindle bearing temperatures, absolute vibration levels and tool imbalance, and can instigate a ‘spindle stop’ when pre-determined limits are exceeded.
