Punching, cutting, cropping and notching on one machine
Added to MTDCNC by RK Int Machine Tools on 26 February 2015
Now available from RK International is  the new Kingsland Steelworker machine that can provide five different processes in one machine. The five working stations that enables two operators to utilise the machine simultaneously include a punching station, a guillotine for cropping steel bar and a notching station for cropping square sections out of steel plate and bar.
The new innovative work station delivers a host of benefits that include multiple work stations in a compact footprint with a single power source. Ideal for job shops rather than production environments, the Kingsland Steelworker is an exciting workhorse for the everyday subcontract manufacturing sector. For higher production environments, Kingsland can provide a higher specification machine with a full CNC control unit to meet these demands.
The Steelworker has an hydraulic circuit that is activated by a shielded foot-pedal  with the low power inch mode on each workstation that enables the correct workpiece-positioning and tool-alignment. Limit-switches also allow accurate adjustment of the stroke length for maximum efficiency.
On the cutting station, angle iron can be cut on every angle from 45º up to 90º, both internal and external, without any adaptations to the machine. Flanges from larger angle-iron can be mitre cut with the shear. Moreover, the machines are equipped with centralised pressure lubrication, a feature that contributes to low maintenance requirements.
The universal steelworkers are delivered with an extensive range of standard equipment, such as large heavy-duty tables on the punch, shear and notching station. Easy adjustable hold-downs to enable production in a safe and accurate way are fitted on every station
LATEST PRODUCTS FROM RK Int Machine Tools
What are you looking for?
What is 2 + 6? (Spamcheck)
