View by company
View by company
View by company
Successful Gear Machining Seminars
A pair of successful one-day seminars on gear manufacturing was held at NCMT’s Coventry technical centre and showroom on 27th and 28th June. Over 70 visitors learnt that it is possible to achieve world-leading accuracy when producing gears and splines on standard machine tools built by Okuma, Japan, whose products are sold in the UK and Ireland exclusively by NCMT.
The company’s engineering director Adrian Maughan said, “There is an increasing interest in producing gearboxes that are more compact, lighter and more efficient.
“The flexibility, high productivity and lower investment cost offered by producing gears on 5-axis machining centres or multi-tasking lathes from Okuma, coupled with their high levels of accuracy and repeatability, makes them ideal for the purpose.
“We not only showed the wide range of external and internal gear types that can be machined but also proved the high level of precision attained by measuring them on our recently installed Leitz CMM equipped with the latest Quindos software.”
NCMT believes that the combination of hardware and software offered on standard Okuma machines places the company at the forefront of gear production on a multi-tasking platform. Demonstrations at the seminars were performed on a Multus U3000 2SW turn-mill centre, while power skiving also ran on an MU4000V-L 5-axis vertical machining centre.
Power skiving is intended for producing gears in large volumes to high accuracy using a dedicated tool for each type and size of gear. The skiving tool sequentially roughs and finishes the component. The 3.9 module spur gear produced during the demonstrations had a deep tooth profile that requires robust machine tools to skive the finished product from a solid billet.
NCMT proved on its Leitz CMM that a Class 6 spur gear was achieved by power skiving on the Multus machine. Accurate synchronisation between rotation of the tool and the workpiece is essential to achieve this level of accuracy.
Another process demonstrated was InvoMilling, a flexible machining technique as it is capable of producing different gears using the same standard milling tool. Helical and spur gears ranging from module 2 to 12 can be produced with just two tools, for example. Other tools are available to cover a module range of 0.5 to 100.
This process is ideal for prototyping and small to medium batch production, as well as for producing larger modules, pinions and complex gears such as a herring bone with gap. Neither is there any limitation to the root form. Due to the use of standard tools, it is possible to save many weeks in manufacturing lead-time by not having to wait for special tools to be delivered.
Other gear production techniques and their relative benefits were covered during the presentations, including hobbing using a carbide inserted cutter, shaping and spiral bevel milling.
Thermal growth compensation
The dimensional accuracy achieved on Okuma milling and turning machines, and the ability for machined gear tooth flanks to appear as though they have been ground, require comprehensive management of thermal growth. The machine builder’s technique for effective control lies in the design and construction of its machines for predictable movement, whereby deformation occurs in a linear and predictable manner.
Okuma calls its compensation system the Thermo-Friendly Concept, which combines the attributes of the machine construction, open-architecture OSP control and design elements such as covers and peripheral equipment that eliminate hot spots and help equalise ambient temperature variations. The approach uses two thermo-active stabiliser systems to monitor growth, one controlling the spindle while the other controls the structure. They help maintain the accuracy of the entire machine tool, even in environments where temperature variation of up to 8°C occurs.
This is just one of Okuma’s intelligent technology offerings, which also include advanced automatic collision avoidance; Machining Navi, which assists operators by recommending optimal cutting conditions and parameters to suppress chatter; and Okuma’s 5-axis auto tuning system that accurately fine-tunes the geometry of the machine, including the straightness of the axes.
Okuma is highly unusual in that it manufactures practically every part of its machines, including the spindle, drives, rotary encoders with an astonishing 36 million increment resolution, AbsoScale linear scales guaranteeing 0.05 micron feedback and even the proprietary OSP control.
Published on MTD CNC by NCMT Ltd on 03 July 2017
Have you seen these videos all relating to NCMT Ltd?
Available to purchase from NCMT Ltd
Enquire with MTD CNC TODAY
Spam check: What is 6 + 7?
