New Hyundai L800LMA and L160MA turning centres from TW Ward
Added to MTDCNC by TW Ward CNC Machinery Ltd on 03 April 2014
Two new turning centres at either end of the capacity range have expanded the comprehensive portfolio of Hyundai-Wia lathes available from exclusive UK distributor T W Ward CNC Machinery (Ward CNC).
Capable of handling 240 mm diameter bar, the 45/37 kW, 700 revs/min spindle L800LMA with 18-ton clamping power is ideal for highly accurate machining in intermittent and heavy-duty cutting applications for medium/large workpieces.
It has a maximum turning diameter and length of 920 mm and 3,250 mm, respectively, and a swing over the bed of 1,050 mm.
Axes feed rates are 12 m/min in X (500 mm travel) and Z (3,280 mm travel), and 14 revs/min in the 360deg C axis. Milling tools can be driven at 3,000 revs/min. The machine’s 12-station tool turret can index at 0.4 sec/step. Fanuc CNC (32i or i Series) is standard.
At the other end of the scale – though not the smallest Hyundai-Wia turning centre available - the smaller capacity L160MA turning centre can accommodate bar of 45 mm diameter bar, has a 11/7.5 kW, 6,000 revs/min main spindle, plus a maximum turning diameter and length of 310 mm and 550 mm, respectively. Swing over the bed is 600 mm.
Axes feed rates are 36 m/min in X (220 mm travel) and Z (560 mm travel), and 200 revs/min in the 360deg C axis. Milling tools can be driven at 5,000 revs/min and the 12-station tool turret can index at 0.2 sec. Fanuc i Series CNC is standard.
The new models complement a host of Hyundai-Wia turning machines, including vertical CNC lathes, available from Ward CNC.
