Ward Hi-Tech Introduces the Hwacheon Hi-Tech 850L Long Bed CNC Lathe
Added to MTDCNC by Ward Hi Tech Limited on 19 September 2016
With over 15 years of experience of supplying Hwacheon turning products to UK manufacturing Ward Hi-Tech is pleased to introduce the Hwacheon Hi-Tech 850L, an exceptionally strong and rigid machine with a large turning capacity of up to 5.5m bed length this machine is ideally suited to the oil & gas and heavy industry sectors.
This heavy weight machine weighs of 23 tonnes with a 32 inch chuck and offers a maximum turning diameter of 1m, the new 850L can accommodate an extremely diverse range of medium and large components for the heavy industry sectors.
A key feature of the new 850L is the 12 station tool turret. It has a double width turret that can support large cutting tools up to 100mm diameter and boring bars beyond 1200mm in length with remarkable rigidity and precision. The result is a machine tool that reduces vibration and deflection when conducting heavy duty cutting operations on all material types.
As expected with such a robust and large turning centre, the Hi-Tech 850L is manufactured with a fully cast base with a rigid box-way construction that delivers astounding rigidity, vibration damping and surface finishes when machining at large depths of cut.
Despite being an extremely rigid and large machine, the Hi-Tech 850L is also extremely capable with a 4-axis offering and driven tooling with a Y-axis. This enables the end user to machine relatively complex parts to reduce set-ups and changeovers that can be time consuming and complicated with large parts.
Utilising a powerful Fanuc 0iTD control system, the new Hi-Tech 850L is in stock at Ward Hi-Tech to enable potential customers to have demonstrations and view the exceptional capabilities this exceptional machine.
Ward Hi-Tech is the sole UK distributor for the Korean based Hwacheon product line and Ward Hi-Tech always hold a variety of Hwacheon machine tools in stock.
