New Dah Lih’s 5 Axis High Performance Machine Tool
Added to MTDCNC by Ward Hi Tech Limited on 05 September 2016
Ward Hi-Tech has supplied the UK market with the Taiwanese manufacturer Dah Lih Machine Tool product range for almost 20 years and now capitalising on its excellent reputation for building strong, reliable vertical and horizontal machining centres Dah Lih has now expanded its range to include a 5 axis machining centre, the Dah Lih DMX320.
The DMX320 is very much a ‘performance’ machine with spindle speeds of up to 15000 rpm and BBT40 as standard to ensure rigidity, stability and precision.  With 40 ATC and the latest Fanuc control providing ‘Look Ahead’ function this machine stands up strongly against its competition.
Travels are ‘X’ axis 600mm, ‘Y’ axis 55mm and ‘Z’ axis 500mm with a full 360 degree rotating table.  This impressive new model can hold a workpiece of up to 410mm diameter with a swarf auger extraction unit on right and left of the machine ensuring swift swarf removal when machining large components.  Other standard features of the DMX320 include spindle mounted coolant nozzles, fully enclosed guarding, an RS232 interface for communication purposes and Turcite-B guideways.  The machine is also equipped as standard with through spindle coolant, especially useful for deep hole drilling and heavy machining.
Ward Hi-Tech is the sole distributor for the full Dah Lih range of machine tools and always carries a good number of Dah Lih machine models in stock.
