Freddy Launches New 'Micro' Coolant Recovery System - UKMFG
Added to MTDCNC by Freddy products on 26 April 2017
Recognised as the most widely used and well established coolant vacuum range in the world, Freddy Products has now added to its product line-up with the arrival of the new Freddy Micro.
As the name suggests, the new Micro is a compact coolant recycling system that has a 50 litre tank capacity with a 37 litre perforated basket. Designed and manufactured in the UK; the new Micro is manufactured to the remarkably high standards and specifications that has made Freddy a trusted name for decades.
Extremely versatile and mobile, the new Micro has compact dimensions of just 670mm by 430mm by 980mm (LxWxH). The small footprint is a powerful single phase 2kW motor that offers the option of 240V or 110V power source. The motor generates an airflow rate of 3000m3/hr with a water in-flow rate of 238 litres per minute and an out-flow rate of 100 litres per minute. The fluid is filtered through a filterbag, which are available from 1000um down to 5um to ensure the Freddy Micro captures all contaminants from your machine tool.
The powerful and efficient motor, the compact lightweight design, and the robust build quality makes the new Freddy Micro the only choice for small businesses and machine shops that only have an occasional demand for coolant filtration. Additionally, as the smallest vacuum system in the Freddy range the Micro is the most cost-effective unit available as an entry point for customers. The Micro is well suited to companies currently not utilising a fluid recycling system that may be looking to reduce coolant consumption, prolong fluid life, reduce the health risks associated with poor fluid management and even improve machining performance by eradicating the use of rancid coolant. Additional benefits include the potential to significantly reduce expensive fluid disposal costs, improve tool life and remove harmful contaminants that cause bacterial growth in the machine tool.
The new Freddy Micro is finished with a hard wearing powder coated paint.  This durable paint combines with a robust design and high quality components manufactured in the UK to make sure your new Freddy will last for a generation and beyond. Complete with a 38mm hose and gulper tool as standard, with the option to upgrade to a 51mm hose if required as well as a 24 month warranty, the new Micro is a cost effective entry point for coolant recovery.  The Freddy Micro is the coolant recycling vacuum to enable manufacturers of all sizes, in all sectors to witness the huge cost savings that can be achieved by maintaining high-quality fluid in machine tools. For further details on how to reduce your costs and improve your productivity and environmental credentials, give Freddy a call or visit www.freddy-products.co.uk for more information.
