Lubriserv Gets Swarf in a Spin With New Centrifuges
Added to MTDCNC by Lubriserv Limited on 27 May 2016
Manual swarf centrifuges or swarf spinners are ideal for applications involving a mix of different swarf types or low volumes. They can recover oil or coolant and reduce moisture/liquid content down to just 1-2%. When you consider the weight of your swarf can be up to 25% oil, it is definitely worth considering the small investment and fast payback period of a Lubriserv LUBRISPIN centrifuge.
In a typical machine shop using neat cutting oil, the Lubriserv LUBRISPIN centrifuges can reduce oil usage by 80% and manual centrifuges can handle stringy or chipped swarf oil and recover it from a multitude of applications. The Lubriserv manual swarf centrifuges works on the principle of centrifugal separation. The rotor bowl is made from a perforated steel screen that is driven by a motor. The oil covered swarf is loaded in the rotor bowl and a centrifugal force is created in the rotor to separate oil from the surface of the swarf. The recovered oil is drained out through an outlet pipe into a tank/container ready for re-use.
The LUBRISPIN range of manual swarf spinners are constructed for long lasting continuous operation and the units have an interlocked cover to prevent opening the lid during processing. Furthermore, timers for adjusting the cycles, emergency stop switches, signal lamp lights and removable 3mm perforated baskets are part of the package.
The centrifuges are suitable for de-oiling of metal chips and parts with a drying efficiency up to 1% possible. The LUBRISPIN range of Manual Swarf Centrifuges are available in 3 sizes, 25Kg, 50Kg and 100Kg capacities and typically run with a cycle time of 3 minutes at a standard speed of 700rpm. The CE approved centrifuges include a removable galvanized basket, a solid cast-iron base plate, a self-braking motor and an automatic electric system that is IP44 protected. For further details on how Lubriserv can pull profitability from your swarf, call Lubriserv on Tel: 0844 474 3317
LATEST PRODUCTS FROM Lubriserv Limited
