Lubriserv Introduces Extreme Performance Synthetic Cutting Fluid
Added to MTDCNC by Lubriserv Limited on 16 March 2017
The modern CNC machine tool is designed for high speed operation that will deliver improved surface finish, productivity, tool life and even lights out running. Whilst the machine tool may be geared up for such operation, it would all be impossible without the correct high-performance cutting oils.
Conventional neat cutting oils may not provide the performance required to realise the benefits so desired by users of the modern high-end machine tool. Without high quality neat cutting fluid, customers can witness various problems such as overheating, poor tool life, smoke and fumes, sticky residue on the parts and machine as well as an increased potential for fire.
The new LUBRICUT XS9 from Lubriserv offers extremely high machining performance. It is mineral oil, heavy metal and chlorine free with a low viscosity that has been specially developed as a synthetic fluid that delivers the ultimate-generation EP additives. It is based on high quality synthetic ester and due to its affinity for metal surfaces, it improves the strength of the lubrication film and allows a greater friction reduction.
LUBRICUT XS9 has a very high flashpoint and excellent combustion resistance. This significantly reduces the possibility of ignition caused by naked flames or hot/molten metal. Its low viscosity keeps the machine tool cleaner with less dragout on the swarf and a much lower oil consumption.
The innovative new fluid has been especially designed in order to satisfy all the severe drilling, threading and metal cutting applications of ferrous and non-ferrous metals. It provides excellent cutting performance on difficult to machine metals such as stainless steels, titanium and nickel alloys. For further details, get in touch with Lubriserv.
LATEST PRODUCTS FROM Lubriserv Limited
