Swarf Centrifuges Put Coolant Recovery in a Spin
Added to MTDCNC by Lubriserv Limited on 11 July 2015
Oil recovery is increasingly prominent in the face of costly oil purchasing and even more costly disposal. To reduce the cost element, Lubriserv has now introduced its new line of manual Lubrispin swarf centrifuges.
The new Lubrispin centrifuges are ideal for applications involving a mix of different swarf types or low volumes. The centrifuges can recover oil or coolant and reduce moisture/liquid content down to just 1-2%. When you consider that the weight of your swarf can be up to 25% oil, it is definitely worth considering the small investment in a centrifuge as the payback is remarkably fast.
In a typical machine shop using neat cutting oil our centrifuges can reduce oil usage by 80%.The Lubrispin manual centrifuge can handle stringy or chipped swarf and recover oil from various applications, including CNC machining swarf, gear manufacturing, fastener manufacturing, spring manufacturing, gun drilling, sliding head machining and plated components - making them suitable for all industry sectors.
The Lubrispin manual swarf centrifuges work on principle of centrifugal separation. The rotor bowl is made from a perforated steel screen that is driven by a motor. The oil covered swarf chips / parts are loaded in the rotor bowl and the centrifugal force separates oil from the surface of the swarf chips / parts. The recovered oil is then drained out through an outlet pipe and into a tank for re use.
The units have an interlocked cover to prevent opening the lid during processing, timers for adjusting the cycles, emergency stop switch, signal lamp lights and removable 3mm perforated baskets. in addition, the Lubrispin can be applied to drying, rinsing, degreasing, washing and coating processes.
The Lubrispin is available in 3 sizes that include 25Kg, 50Kg and 100Kg capacities that all run with a cycle time of 3 minutes at a standard speed of 700 RPM utilising an electrical power supply of 400V/50Hz.
LATEST PRODUCTS FROM Lubriserv Limited
What are you looking for?
What is 8 + 1? (Spamcheck)
