Tritan drills from MAPAL have established themselves across the board due to their great economic advantages and now there are four new designs to complete the range of products.
The Tritan-Drill-Uni for machining steels, stainless alloys and cast materials has been further developed and improved with regard to its tool geometry. The new Tritan-Drill-Uni-Plus has a clear advantage over the previous drill for universal use. The new finished groove profiles improve chip removal and a new wear-resistant coating increases tool life by up to three times. In shank form HA, the Tritan-Drill-Uni-Plus will be available in diameters from 4 to 20mm and in lengths of 5xD and 8xD as standard.
For use in aluminium and cast materials, MAPAL now presents the new Tritan-Drill-Alu and the Tritan-Drill-Iron. Thanks to innovative tool geometries, the drills also achieve significant increases in feed rates and performance in these material groups. The Tritan-Drill-Alu has a polished groove profile matched to aluminium materials. Large chip spaces and a special, sharp cutting edge preparation ensure optimum chip formation and reliable chip removal. For cast machining, the Tritan-Drill-Iron impresses with its corner radius design that demonstrates greater stability and wear resistance of the cutting edge. In conjunction with a wear-resistant coating, cast materials can be optimally machined with the Tritan-Drill-Iron. Both designs are included in the range of products as application-specific special solutions.
Finally, the Tritan-Step-Drill-Steel was developed for stepped bores in tapped drill holes. Until now, only double edge drills were available for these machining operations. The flat chisel edge in the centre of these tools make them oscillate up and down along the chisel edge, which leads to a high load on the cutting edges and guiding chamfers and thus to poor results with regard to circularity and cylindrical form. Now the Tritan-Drill-Steel, utilises triple edge technology that eradicates this issue.
The new Tritan-Step-Drill-Steel has an innovative point thinning and finely ground chip flutes, so the chips are rolled tightly and broken. The chips are reliable removed through the relatively small chip flute. The crowned cutting edge with a pulling cut from the centre to the stable cutting edge reduces the load and makes the drill robust. In conjunction with a wear-resistant coating, the machining results of the Tritan-Step-Drill-Steel are excellent, especially when compared to conventional double edge step drills. The Tritan series of drills can achieve double feed rates –while simultaneously increasing tool lives.
