Triag Sputnik Workholding by REM Systems is out of this World
MTDCNC’s Tom Skubala is at REM Systems checking out their space age looking workholding. the Triag…
A strong connection between clamping elements and workpiece is the decisive factor for holding of blanks. Due to the minimal clamping height and maximum holding power of the stamping jaws, the blank clamp perfectly complies with the requirements
Intelligent, centric, automatic
The geometry of the blank clamp is designed in such a way that plenty of machining space remains with an assembly height of only 100 mm. Thanks to the embossing technique, workpieces are held stable and centrically with a clamping height of only 3 mm. Thanks to the integrated interface, nothing stands in the way of automation using robots.
