Seco’s new Double Quattromill® 22 face milling cutters are first choice for heavy-duty milling operations | mtdcnc.com
Did you know the browser you are using is out of date?
Your browser is out of date and may not correctly display content on our website. Below is a list of supported browsers and their download links.
Chrome
Firefox
Safari
Edge
Internet Explorer 11
View by company
View by company
View by company
All Suppliers
Double Quattromill® 22, Seco’s latest range of innovative and high-performance face milling cutters, is designed to help component manufacturers significantly improve metal removal rates and, by doing so, increase productivity levels.
The new cutter range, designed for both roughing and semi finishing operations, feature double-sided inserts with eight cutting edges that enable higher depths-of-cut to be taken.
The Double Quattromill® 22 comes in 45° and 68° lead angle versions for depths-of-cut up to 9mm and 11mm respectively.
The double-sided inserts used in the Double Quattromill® 22 range of cutters generate lower cutting forces and consequently, they require less machine tool power and provide customers with longer tool life.
Double Quattromill® 22 cutter bodies are available with fixed-pocket and/or cassette type options with standard or close pitch versions.
The cutters also feature Seco's new surface texture technology on their cutter body flutes to improve their durability and facilitate more effective chip control and evacuation.
The Double Quattromill® 22 offers a comprehensive range of inserts, with various geometry and grade combinations to suit most materials.
ME12 geometry inserts are aimed at the machining of superalloys and stainless steels. M12 geometry inserts are available in many grades and can be used to machine most workpiece materials. M18 geometry inserts, with their stronger edge protection, are designed for machining steel and cast iron.
Published on MTD CNC by Seco Tools (UK) Ltd on 09 April 2019
Have you seen these videos all relating to Seco Tools (UK) Ltd?
Available to purchase from Seco Tools (UK) Ltd
Enquire with MTD CNC TODAY
Spam check: What is 7 + 9?
Please verify your account
Email Address unavailable
Username unavailable
Incorrect log in details
Password Reset Request
Account Verified
Thank you for verifying your account
Pleae feel free to comment on all videos on MTDCNC, join our community
