Trunnion-Style High-Rigidity Machining
In the world of precision engineering, accessibility and rigidity matter. Join us as we explore the…
We are proud to be designated as Main Dealer Europe for Toshiba Machine of Japan who, as a recognised world leader in the machine tool industry, uses the latest technology to meet the needs of all major industries. The range of CNC machine tools includes machining centres, boring machines, gantry mills and 5-axis machines. Toshiba Machine manufacturers almost everything from start to finish – castings from their own foundry and their own control systems ensure total machine integrity and compatibility.
Toshiba Machine machines are found in aerospace, power generation, automotive, marine, construction and transportation industries. The vertical boring machines are perfect for all of these industries for the following reasons;
The TUE 150 and 200 series are available in the ‘S’ model having a positional C-axis and driven tools and many attachments and angle heads can be provided. One of these machines, TUE-200(S), can be seen in our Nuneaton showroom and is available on immediate delivery.
For a machine with a Ø1M table, the turning performance of the TUE-100 is exceptional. The 45kW drive motor provides a turning speed of 600rpm and 9,800N.m of torque. The identical ram cross-section as on the larger models ensures heavy duty cutting capability and the ram can withstand a cutting force of 19,600N. The machining area is totally enclosed providing a clean working environment and the machine is fitted with a Fanuc Series Oi-TD control.
Several sizes of TUD models of vertical borers are available. TUD is a turn only model and many attachments and angle heads can be provided. This model is available as either single table or twin pallet.
The TSS-C single column vertical turning lathe has the additional benefit of a movable X axis carriage enabling the machine to process components nearly twice the diameter of the rotary table. The single radial elevating crossrail on which the ram carrier is mounted uses a patented automatic compensation system to maintain straightness. A live spindle can be provided for boring, drilling and tapping operations.
The TMD range has various different machines within the range and all having a gearbox driven C-axis and driven tools. Many attachments and angle heads can be provided and the TMD is available single table or twin or multi pallets.
The newest range of vertical boring mills, TDS has been designed to process medium sized parts up to 5M in diameter, 2.75M high and weighing up to 30 tonnes. The double column construction, long stroke elevating rail, enclosed ram and high torque table provide the TDS with exceptional metal removal capability. These machines are available as turn-only or with C axis and live spindle.
